Append to logfie option not working for workspace in workspacerunner?
  • July 22, 2016
  • 88 views
I have a workspace that has a Workspacerunner transformer. I find that the 'append to logfile option' works for this workspace, but not for the workspace defined in the workspacerunner. The logfile of the workspace in the workspacerunner contains only the last run, where I hoped the logfile would contain accumulative messages from all previous runs.
Am I right about this and is there a workaround?
Thanx again for any response!
Regards,
Pim
Best answer by markatsafe
I tested this in FME 2016.1 and it does appear to work OK. But what you have to do is to open the 'child' workspace in FME Workbench and set the Append Log File under the FME Options -> Translation parameters. Setting the Append Log File in the 'parent ' workspace that has the WorkspaceRunner transformer will only affect that workspace.
  • July 27, 2016
  • July 28, 2016
IHi Mark, I thought I did that too. Maybe I didn't or maybe I needed to save the child workspace after setting the option. Anyway its working fine now. Thank you! @MarkAtSafe
  • November 17, 2017
I thought those options were global to FME Workbench, like the python interpreter. There is no "save" needed after setting the Append to log file check box.
Hi, I had the same problem with FME 2019.
And indeed, I had to re-open the child workspace too, uncheck and re-check the option "append to logfile" and make any modification in the workspace to enable the "save" button and save the workspace.
Then, FME appended correctly the logs in the same log file.
This process is really not intuitive...
