AppearanceSetter does not work with attributes
  • Feb 5, 2018 3:46 PM UTC
  • 150 views
mhab
Forum|alt.badge.img+10
I want to apply color to 3D features via FME attributes.
To my disappointment I found that AppearanceSetter does not allow attribute values for color setting. AppearanceStyler does however.
Problem now is I have to split my stream of features in order to get one stream with the features, the other stream with the appearances so I can use the AppearanceSetter to finally apply the appearances.
Do I need to create unique Ids for each feature in order to get this working properly, or is there an easier way to do this ?
Any reason why AppearanceSetter doesn't allow me to do this directly ?
Thanks for any hint
Best answer by nathanatsafe
Hi @mhab,
I think that the GeometryPropertySetter might help in this situation, as it will set the Geometry trait that the AppearanceSetter uses to join your appearance and geometry features. You can set the Geometry trait to an attribute that exists on both of your streams of features.
Hope this helps.
Nathan
nathanatsafe
Forum|alt.badge.img+9
  • Feb 14, 2018 7:42 PM UTC
Hi @mhab,
Hope this helps.
Nathan
