Anchored snapper - problem snapping polygons to lines
  • Aug 16, 2018 1:55 PM UTC
  • 120 views
eric_armitage
Forum|alt.badge.img+11
Hi
I'm trying to use the anchored snapper to snap polygon boundaries to cadastral lines. However, it only seems to snap the vertices of the canditates and doesn't create extra vertices in between to make the polygon boundary align to the cadastral. Is there a way to force it to create additional vertices where necessary?
davideagle
Forum|alt.badge.img+21
  • Aug 16, 2018 1:58 PM UTC
In cases like this it may be worth considering passing your data to snap through a Densifier transformer ahead of the Snap to make it more likely to produce a good result.
Make sure you set snapping type to segment snapping:
eric_armitage
  • Aug 17, 2018 6:11 AM UTC
Yes i tried that but it only seems to snap the end points of each canditate segment. It doesn't create extra vertices/ segments in the canditate to match the anchor.
