analyzing points on routes
  • May 20, 2015
  • 33 replies
  • 190 views
Show first post
  • July 22, 2015
Sorry, the "Input is Ordered by" didn't work as expected in my quick test.
?Now, I cannot provide any idea to resolve the memory issue...
  • July 22, 2015
I found that the parameter works as I intended if you sort points and lines together like this.
franco69
Forum|alt.badge.img+11
  • July 24, 2015
Hi Takashi,
the "YES" in INput is ordered by group should be right.....one step forward...but now i have a new problem....
it seems the memory problem is now anyhow solved....but FME writes one feature after PoinONLIneOverlayer and MeasureExtractor in the Geodatabase but the it stops and log the error NULL pointer check failed...
what is this? what can I Do?
Thanks and greetz
Franco
  • July 24, 2015
Could you please paste the error message as-is?
franco69
  • July 24, 2015
2> NeighborFinder(ProximityFactory): Processing 15.62% complete
NULL pointer check failed. File: geodbfeatureclass.cpp Line #: 1010
|ERROR |
... Last line repeated 2 times ...
Output_From_6::TransporterReceiver(TransporterFactory): A fatal error has occurred. Check the logfile above for details
f_32(TransformFact): A fatal error has occurred. Check the logfile above for details
Feature output statistics for `FFS' writer using keyword `W_1':
Features Written
Total Features Written 0
GeodatabaseRelationshipFeaturesPipeline::GeodatabaseRelationshipFeatures(SortFactory): Sorted 0 feature(s)
Transaction #1 rolled back. Rerun translation specifying transaction #0 for the keyword 'TRANSACTION'
Closing the Geodatabase writer
Feature output statistics for `GEODATABASE_FILE' writer using keyword `GEODATABASE_FILE_2':
Features Written
locate_pts_5_3 1
Total Features Written 1
FME Session Duration: 38 minutes 55.3 seconds. (CPU: 2077.2s user, 221.7s system)
END - ProcessID: 138332, peak process memory usage: 3341676 kB, current process memory usage: 407360 kB
Program Terminating
Translation FAILED.
screenshot
  • July 24, 2015
Looks like the error occurred during parallel processing in the NeighborFinder.
I'm not sure what the exact reason for the error is, but the parallel processing might be concerning to that.
How about setting "No Parallelism"?
franco69
  • July 24, 2015
With " No Parallelism" in the NeighborFinder nothing changed.....
  • July 24, 2015
sad to hear that...
sorry, I don't have any idea to resolve the error.
