AM PM to 24 Format
  • Mar 27, 2019 3:55 PM UTC
  • 167 views
jugoslaviaa
Hi everyone,
I have attribute values like 7-10A, 6A-8P etc and I would like to convert them to 24 Hours format as in the following
  • 7-10A to 7-10
  • 6A-8P to 6-20
  • 10A-3P to 10-15
Any idea how i can do it? Many thanks
Best
Best answer by david_r
I would consider using an AttributeSplitter followed by the DateTimeConverter. You can then join the start and end times back together in the end, if needed.
  • Mar 27, 2019 3:59 PM UTC
jugoslaviaa
  • Mar 28, 2019 12:23 PM UTC
DateTimeCoverter did not help or I could not figure out to use. I basically had to split by - and then try to convert to 24 i.e. Check if the sring is A, number stay as it is or if it is P, add 12 to the value
