Align label with line
  • Jul 28, 2020 9:41 AM UTC
  • 11 replies
  • 228 views
@takashi
Hi !
Any hints how to align label with the line direction ? I'm using a 2DVectorCalculator, Featuremerger, offsetter and vertex creator. But I'm not always having the right orientation of my labels with the line direction. See below attached images. Thank you in advance.
Best answer by caracadrian
The Forum becomes Read only in a few minutes (https://knowledge.safe.com/questions/117555/important-notice-community-migration-service-outag.html ) so email me at if you have further questions
@sam.27​ You should start with the ProfileGenerator custom transformer, right click it and than click edit. Copy paste everything in your workspace, than customize to your needs.
Customise ProfileGenerator
The red bookmark that I created is an idea of what you need. You label the vertexes and offset them with something constant (constant + z*VerticalExageration - or @YValue*VerticalExageration).
For partial distances you Chop by 2 vertexes, generate the 2D measure of each line, label it and offset that label to the place you need it to be.
Please mark the question as answered, I want to know what the new badges look like :D
caracadrian
Forum|alt.badge.img+23
  • Jul 28, 2020 11:33 AM UTC
Can you tell us what are you trying to label?
For line labeling you can use the Labeller transformer.
For labeling points with the orientation of the line you can also use the NeighborFinder to get the angle and than the LabelPointReplacer
  • Jul 28, 2020 11:40 AM UTC
I'm labelling the attribute showing depth at each vertex.
caracadrian
  • Jul 28, 2020 12:20 PM UTC
You can get something like this:with this:
I input a 3Dpolyline that I chop in to vertexes than I get their neighbor, label the vertexes and set their rotation via the fme_rotation attribute.
If you want to set the rotation to the angle of the line that goes from the previous vertex to the next vertex you can create attributes for X and Y, than Enable adjacent feature attributes in an AttributeManager and do the math (atan(dX/dy) plus or minus depending on x and y grater than or less than 0, you have 4 situations. Don't forget about pi()/180...)
  • Jul 28, 2020 12:30 PM UTC
Oh great! It works very well ! Thank you.
I have another question, do you know if it is possible to create label shown in rectangle from the figure below: It's a DWG file.
caracadrian
  • Jul 28, 2020 1:50 PM UTC
Sure, just use a lot of LabePoinReplacers coupled with Offseters, get the BoundingBox, draw the line.
Here is a demo workspace labelpointinbox.fmwt
caracadrian
  • Jul 28, 2020 1:53 PM UTC
  • Aug 6, 2020 7:33 AM UTC
Hi Adrian,
Thanks a lot, I've added a buffer to keep the characters inside the label not too close to the border!
Could you please help me with another Issue, I need to make an elevation profile of a pipeline like in the attached dgn file.
Thanking you in advance.
caracadrian
  • Aug 6, 2020 8:01 AM UTC
caracadrian
  • Aug 6, 2020 8:06 AM UTC
Meh.. I liked the old forum badges better
  • Aug 6, 2020 8:09 AM UTC
🙂 Thanks again for your help ! Have a nice day Adrian !
caracadrian
  • Aug 6, 2020 8:27 AM UTC
Anytime
