Align CAD to GIS layer
  • Dec 27, 2017 5:06 PM UTC
  • 74 views
apence231
Forum|alt.badge.img+10
I have a CAD file that looked to be in local coordinates and I finally found the handy tool 'Local Coordinate System Setter' and I reprojected it into state plane and almost got the CAD drawing in the correct location but it is still off by a bit and not sure what I am missing.
I've tried the Affiner tool to get the direction correct since i noticed in the CAD drawing it has _xdir_x and _ydir_y and so on.
Adding those directions into the Affiner tool, it rotated at least correctly but not quite in the right location (blue CAD, green GIS):
Is there another tool that i need to use to make it align better or at least get the CAD drawing in the exact locations?
Thanks!
erik_jan
Forum|alt.badge.img+26
  • Dec 27, 2017 5:23 PM UTC
If all coordinates are off in the X and Y direction by the same distance, you could use the Offsetter to correct that.
apence231
  • Dec 27, 2017 7:43 PM UTC
It's always the most simple things sometimes! Don't know how i missed that, but using offsetter and also rotator i was able to align it and then I used snapper to get it all set up. Thanks for helping me with the brain-fart.
