AGOL Writer Attributes
  • Jul 17, 2024 5:49 PM UTC
  • 132 views
scottshenberger
Hello,
I have a workbench 2022.2 that writes out data from a join of another feature service to an SDE feature class out to an existing service. I am using an attribute manager, see below, before a date formatter and reprojector. However, when I run the workbench, the writer always gives me a mismatch on attribute sizes error in manual and automatic modes. I have tried to update the attributes to the values listed in the error but it always seems to revert back. I know I am missing something simple but for the life of me I cannot see what.
Thank you for your time.
Scott
natalieatsafe
Forum|alt.badge.img+12
Hi @scottshenberger , thanks for the question! Are you able to provide a full translation log which contains the error you’re seeing at the writer? It might give us some additional clues if we can see the exact error. Thanks!
scottshenberger
Hello,
Attached is the error log. The two values i have updated/changed to match the server value twice this morning. When I go in and change the values in the writer and re-run, two more values seem to revert back to the pervious writer values.
scottshenberger
my apologies,
I uploaded the wrong log
scott
