aggregator removes overlapping parts in FME?
  • November 16, 2014
  • 15 views
Hello, Does anyone know this question?
When I do the clip operation of two polygon layers, invalid geometry error rises.
And after my test, I knew it's the aggregator operation generates some self-intersection problems.
In my test, I generate a Polygon Layer which contains some small polygons, and some are overlapped(here we name it as Layer A), then I use dissolve operation in ArcGIS to dissolve these polygons(here we name it as Layer B), next I use the aggregator operation in FME to aggregator all polygons(here we name it as Layer C).
Then I check geometry for Layer B and Layer C. Layer B is ok, having no genometry problems, whereas the Layer C has self-intersection problem.
And when I look into Layer B and Layer C, I found that in Layer B, all the polygons is dissolved, including those overlapping parts. However, in Layer C, those overlapping parts are ignored. (The pictude is as follows:)
So, is the aggregator operation in FME doesn't equal to the dissolve operation in ArcGIS? If so, are there any similar operations I can use in FME which considering these overlapping parts when dissolving?
[Original polygons which have overlapping parts]
[Result of dissolve operation in ArcGIS]
[Result of Aggregator Operation in FME]
  • November 16, 2014
Thanks, I now found it seems that FME has the dissolver itself, I will try it~
  • November 16, 2014
After I try, I know that the dissolver transformer + aggregator transformer can works! Thanks!
