Aggregate by time but date issues
  • Sep 11, 2019 6:25 PM UTC
  • 44 views
Hi All,
We are trying to transpose some data and have run into a little issue
When we go to aggregate the data back, we get almost the correct data but we are aggregating by time so we get hourly data in columns broken down by hour in the following require format:
Times
Mon 01/01Tue 02/01Mon 08/0101:00-02:0043302:00-03:00333
The data is coming out exactly how we want however if we have duplicate days and we are using a group by on aggregation by time, it is missing where we have duplicate days like the above two Mondays in the concatenation on _attr_value as we cannot separate the times on the two Mondays.
We just end up with 5 comma separated values instead of 6 in the concatenation.
We followed this guide to transpose our row data to column data - https://knowledge.safe.com/articles/31701/transpose-a-table-using-fme.html
Any ideas would be appreciated
Current example input
_attr_value time uid
98 22:00-23:00 17A
95 23:00-24:00 17A
94 05:00-06:00 17A
92 23:00-24:00 17A
91 05:00-06:00 17A
9 02:00-03:00 17A
85 05:00-06:00 17A
grouping by the time field and a uid.
CURRENT example output:
00:00-01:00,32,37,38,38,40
01:00-02:00,15,16,16,17,23
02:00-03:00,14,14,9,16,11
03:00-04:00,14,15,19,18,23
04:00-05:00,29,31,38,35,37
05:00-06:00,101,94,85,91,100
gio
Forum|alt.badge.img+15
  • Sep 12, 2019 2:58 PM UTC
@lemzip
If i get the question(?)
Use datetime as group by value. (instead of time)
Or select both time and date as groupby values.
Latter would be less work as you dont have to create datetimes of all the times and dates.
