Affine Warper transformation gives no output
  • August 27, 2020
  • 81 views
Hi All - I am attempting to take a geo polygon and shrink, rotate, and offset the polygon to the correct location. For this I was attempting to use Affine Warper. The polygon I'm trying to change is the "Observer" and I have a geojson polyline with 2 points as the "Control" that I want to shrink the polygon down inside. No output is given in the Affine Warper.
Best answer by virtualcitymatt
If you check you should have a warning in your logfile:
"AffineWarper (WarpFactory): Must have at least 4 control points to perform an AFFINE transformation."
Try creating another vector to help FME generate the transformation it needs to apply.
Here is a quote from the documentation:
"Each Control feature represents a control vector (a 2-point line feature) whose start point is at some location in the original Observed data space, and whose end point is at the corresponding location in the desired output data space. Each control vector represents the correction required to go from the observed vertex to the desired vertex, in terms of direction and distance. Control vectors with only one point are interpreted as a requirement that this location not change from the observed dataset to the reference dataset. This is often referred to as a tie point."
virtualcitymatt
Forum|alt.badge.img+47
  • August 27, 2020
  • August 27, 2020
As mentioned by @virtualcitymatt​ , you'll need more Control vectors. In this case you'll need four 2-point line features, i.e. 4 features entering the Control port.
Thank you, these answers totally solved my problem!
