address locator
  • Apr 25, 2018 4:46 PM UTC
  • 7 replies
  • 199 views
Is there a transformer that creates an ESRI AddressLocator tool?
erik_jan
Forum|alt.badge.img+26
  • Apr 25, 2018 5:47 PM UTC
I think you can use the ESRI geocoding service in the Geocoder transformer.
erik_jan
  • Apr 25, 2018 5:49 PM UTC
If not the Hub has a geocoder for ArcGIS Online.
bruceharold
Forum|alt.badge.img+20
  • Apr 26, 2018 2:54 PM UTC
If the question is whether any transformer can create an ArcGIS address locator object on disk, then no, unless you script something that calls ArcGIS geoprocessing.
timboberoosky
Forum|alt.badge.img+7
Is this still true with newer releases of FME?
danminneyatsaf
Forum|alt.badge.img+13
Hi @timboberoosky​,
There are currently no transformers that use the ArcGIS Address Locator directly. However, you could use ArcPy and a PythonCaller as a workaround if you wanted to use this tool.
Additionally, as others have stated above, you have the option to use the Geocoder transformer which you can set to use ArcGIS Online as the Geocoding Service. This article provides a handy overview of how to geocode addresses: https://community.safe.com/s/article/geocoding-addresses
timboberoosky
Hi @timboberoosky​,
Thanks @danminneyatsaf​ . I'm looking to create stand-alone locator files to subsequently publish as in-house geocoding services so can't use ArcGIS Online. I'll go the PythonCaller route. Thanks again.
bruceharold
  • Oct 8, 2021 3:06 PM UTC
Hi @timboberoosky​,
You'll need to call Create Locator from ArcPy, I recommend capturing the Python from a History item, the parameters are numerous.
