Adding unique attribute values to more than one Feature
  • Apr 24, 2018 8:31 AM UTC
  • 6 replies
  • 189 views
Hello,
I hope FME community can solve my problem. I have polygons that represent parcels, polygons that represent buildings, and points that represent parcel and building numbers. I need to add unique identifier to parcels, buildings, parcel id and building id that are on the same parcel. I have attached a picture so I could explain what I need easier (1.png).
I have a parcel 2375 and I need to add to new attribute, lets say ID, value 111111 to polygon parcel with id 2375, point parcel_num with parcel_id 2375, polygons buildings 1, 2, 3, 4 and point building_num with build_num 1, 2, 3, 4. All objects in one parcel need to have same identifier in their attribute lists.
I will use attributeManager to add new attribute all Features, and Counter to add unique value but I don't know how to group all objects to parcel.
Best answer by oscard
I would give a unique identifier to every parcel using Counter (as you have mentioned).
Then, I would use a SpatialRelator to know to which parcel the buildings and the point features belong.
I guess that you will need to create polygons with holes for some of the parcels. For example, the parcel 2375 should have a hole with the shape of 2374.
oscard
Forum|alt.badge.img+23
  • Apr 24, 2018 8:37 AM UTC
Forum|alt.badge.img+63
In order to create parcel polygons (assuming you don't have them yet) you can use the AreaBuilder, that'll have the option to create donuts. Then a PointOnAreaOverlayer to transfer the parcel number to the parcel polygon and the SpatialRelator that @oscard mentioned to find out which buildings are on which parcel.
  • Apr 24, 2018 9:12 AM UTC
Once again FME community saves the day. Thank you @oscard this works perfectly. I don't need to make holes because i made my polygons from lines with LineCloser, Matcher and areabuilder so on output end holes are already there, but thanks again.
  • Apr 24, 2018 9:14 AM UTC
Thank you @redgeographics for your input. I used NeighborFinder with merging attributes for parcel and buildings numbers, but good to know that there are other ways to do the same thing.
I would be very weary to use the NeighborFinder, as it will look for the closest match. That may not be a problem with your data but I'm sure I can come up with scenarios where it will pick the wrong one.
  • Apr 24, 2018 9:35 AM UTC
Yes, yes i know but in my data it can pick up only one number and the max distance is set to 0 because every number(point) is placed inside polygon during preparation of data. If something changes i will use your idea. Thank you.
