Adding transparency to AutoCAD DWG file
  • Mar 14, 2018 5:22 PM UTC
  • 7 replies
  • 241 views
Is it possible to add transparency styling to DWG output via FME? There doesn't seem to be an option in the DWG styler. If there is an appropriate field in the autocad format attributes i can overwrite this value but I can't see anything relating to transparency.
Best answer by daveatsafe
Hi @proudgis,
I'm sorry, but FME does not currently support transparency in the AutoCAD DWG reader/writers. We are working on adding this support, and I will notify you as soon as it is available.
daveatsafe
Forum|alt.badge.img+24
  • Mar 14, 2018 6:35 PM UTC
Hi @proudgis,
danilo_fme
Forum|alt.badge.img+58
  • Mar 14, 2018 10:10 PM UTC
Hi @proudgis,
Great @DaveAtSafe Very interesting.
sigtill
Forum|alt.badge.img+25
  • Oct 1, 2019 9:49 AM UTC
Hi @proudgis,
Any progress on this?
gio
Forum|alt.badge.img+15
  • Oct 1, 2019 3:29 PM UTC
@proudgis
You could use pyhton or superior TCL, using comtypes opening dwg, calling LISP to apply transparency (and other operations of course) to do that.
You can find examples of such on the net.
For instance a quick hit : https://stackoverflow.com/questions/48794935/batch-run-autolisp-with-python
And there are ample examles of transparency setting in LIPS.
Bassicaly layer search and aplplying
(command "_LAYER" "_TR" 45 "Layername" "")
Come to think of it, i posted samish while ago.
Yeah, better for safe to alleviate us from this burden...;)
lazarlubomir
Forum|alt.badge.img+11
  • Feb 17, 2022 12:00 PM UTC
Hello @daveatsafe​ , is there any progress please? :-)
danminneyatsaf
Forum|alt.badge.img+13
Hi @lazarlubomir​, unfortunately the issue has not been fixed yet, but we are looking at adding this support. We'll be sure to post here if a fix has been released!
lazarlubomir
  • Feb 18, 2022 8:47 PM UTC
@danminneyatsaf​ Thx 🙂
