Hi, I have a data set of lines that are part of polylines but i am missing attribute sequence. Attribute sequence is number (starting from 1) that represents order of lines for each polyline. Is it possible to add this attribute in a way that number 1 is first line of polyline, 2 second and so on? If not, how can I add this attribute regardless of position of lines in polylines?
This is part of my data set. First column is ID of line and third one is ID of polyline. I need to add fourth column sequence that will have for example for polyline 0 line 142 value of 1, line 7 value of 2 and line 747 value of 3.
