I need to add point to a line. What i am doing,i am using 2dpointadder to my source line file and adding points from the two x,y columns and mapping these x,y columns to 2dpointadder but problem is , point is added to line but i dont have control over the endpoint of line ,from which side it should be extended. I want htis new point joined to the nearest endpoint of line.
Please help.
Thanks in advance
