Adding more decimal places to geodatabase feature class.
  • Apr 27, 2017 11:04 PM UTC
  • 97 views
Currently, the geodatabase is rounding to six decimal places and I need the latitude and longitude decimal places to go to 10 places behind the decimal as shown in the original data. Is this possible? The geodatabase writer that I am using is uses dynamic properties.
bruceharold
Forum|alt.badge.img+20
  • Apr 28, 2017 2:25 PM UTC
If your DBMS supports it, specify DOUBLE(15,10) when creating the fields, this will support -nnn.nnnnnnnnnn. File GDB doesn't support this.
Thank you!
itay
Forum|alt.badge.img+19
  • Apr 30, 2017 12:46 PM UTC
Optionally if you are writing to a fgdb you can use a text data type for the coordinates.
  • May 1, 2017 10:46 AM UTC
In a File Geodatabase you should use the DOUBLE data type.
