Adding initial digits on coordinates
  • Feb 12, 2018 10:20 AM UTC
  • 64 views
Dear experts,
I have a dwg-file wich is told to be in RT90 5 gon W. I have not been able to position it right though, but now I think I have localized the issue. It seems like the two first digits of all the coordinates are missing. Therefore, I would like to add 6200000 and 1400000 to the coordinates. How is this done? I have tried to set up a new coordinate system with the right parameters but I just cant get it to show up in the coordinate system gallery? Is there maybe a better way?
Thanks.
Best answer by david_r
Have a look at the Offsetter.
Example:
  • Feb 12, 2018 10:28 AM UTC
Example:
  • Feb 12, 2018 10:54 AM UTC
Great, a simple solution that solved my problem!
A huge thank you!
