adding/appending from csv value to excel value
fbastian73
Forum|alt.badge.img+12
hello experts,
I am trying something that to some of you may be quite simple so I hope one of you is able to help me out.
All i am trying to do is to append/add the value cnt from the inlinequerier to the existing excel file.
I am trying to write the cnt value into the count_of_errors value where the incoming feeder name is the same as the destination one (in excel file).
thank you,
fb
Best answer by jkr_wrk
pre-note: I would recommend using FeatureReaders and FeatureWriters instead of Readers and Writers because things will be a bit more intuitive.
You say you want to add data to an excisting Excel-file, but you are reading a CSV file and then using an InlineQuerier to add some other source. This looked a bit confusing to me at first, but I think the InlineQuerier is reading the Excel?
I think I would do the following:
Creator → FeatureReader (Excel) + FeautureReader (CSV) → FeatureMerger → AttributeValueMapper → FeatureWriter (Excel)
I usualy don't like to ‘update’ the same Excel, but write a new Excel with the same data, but it can be done using the xlsx_row_id to write the data to the same row as it came from.
jkr_wrk
Forum|alt.badge.img+29
  • May 6, 2024
fbastian73
  • June 6, 2024
thanks for the recommendations @jkr_wrk.
I used some of the ideas you gave me to work out what I was trying to achieve.
cheers.
fb
