Add vertexes along lines
  • Sep 15, 2014 8:01 AM UTC
  • 500 views
Dear FME community,
I want to add new points (vertexes) to a line. For example:
I have a line of 100 meters with two points (start point and end point). I want to add 9 new points, so that the line gets new vertexes every ten metres. Is this possible in FME "out of the box", or do I new Python for that? The VertexCreator seems to be the right tool, but how can I tell it to add a point in a regular intervall (I do not have list with the new coordinates).
Kind regards from Germany
Thomas
  • Sep 15, 2014 8:29 AM UTC
Hi Thomas,
If the line always has only 2 nodes (start and end), the Densifier transformer might help you.
Just be aware the transformer has two different modes (Exact / Uniform Interval). It depends on your requirement which of them should be applied.
Takashi
gio
Forum|alt.badge.img+15
  • Sep 15, 2014 9:07 AM UTC
Take a look at the cloner/snipper solutions offered in this thread:
https://safecommunity.force.com/CommunityAnswers?id=906a0000000csdWAAQ
gio
  • Sep 15, 2014 9:12 AM UTC
Ah,
did'nt know they now have a transformer for it..lol.
Well, at least for interval types.
No table based densification i see...tsktsk..ommision.
  • Sep 15, 2014 10:09 AM UTC
The densifying by the Densifier will be performed for each segment in a line. Therefore, the Densifier may not work as expected if the input line could be a polyline that consists of 3 or more vertices.
In such a case, see the thread that Gio suggested.
