Add to raster cell value based on value in another raster at same location
  • May 2, 2019 12:18 AM UTC
  • 77 views
rclarkenz
I have two GeoTIFF rasters. A & B.
Each Raster has a different amount of rows and columns. Geographically they are of the same location.
Both Rasters are in the same projection.
What I want to do is grab the cell values of Raster A and add to them the value that is at the same geo location in raster B.
I had hoped RasterExpressionEvaluator or RasterCellValueCalculator would help but seeing the Rasters have different row and column counts it errors.
Any advice would be great, thanks :)
  • May 2, 2019 12:37 AM UTC
You can use the RasterMosaicker to calculate the sum of cell values where the two rasters overlap, after clipping the raster B by the raster A.
