add surface information from raster to vector
  • Oct 4, 2019 2:27 PM UTC
  • 184 views
arjen
Participant
I have got line objects, and a rasterdataset with elevation data.
I try to get both minimum and maximum elevation values as an attribute to the lines, but just can't find out how.
Does anyone know how to do this?
jdh
Forum|alt.badge.img+41
  • Oct 4, 2019 2:35 PM UTC
Buffer the line by a small amount, clip the raster, RasterBandMinMaxExtractor, FeatureJoiner to attach back to the original line.
Use a counter if your lines don't already have a unique ID. It may be more efficient to convert the clipped raster to a point cloud and use the PointCloudStatisticsCalculator to get the Min/Max.
daveatsafe
Forum|alt.badge.img+24
  • Oct 4, 2019 4:25 PM UTC
Hi @arjen,
Another method would be to use the SurfaceDraper transformer. Connect the elevation data to the Points/Lines input and the lines to the DrapeFeatures input. In the transformer settings, set Drape Method to MODEL. Connect the DrapedFeatures output to a BoundsExtractor to get the min/max elevations.
The lines will now have more vertices and be 3D. If this is not what you want, you can use a FeatureMerger to merge the min/max elevation info on a copy of the original features, or you can store the original geometry before draping with a GeometryExtractor and restore after getting the bounds with a GeometryReplacer.
arjen
Participant
  • Participant
  • Oct 7, 2019 6:17 PM UTC
Hi @arjen,
Thank you, this is exactly what I was looking for.
