Add pictures to table in Word doc using Python docx in PythonCaller
  • Nov 28, 2022 10:33 PM UTC
  • 907 views
egge
Forum|alt.badge.img+14
Recently I have been playing/fooling/struggling around with the creation and modification of Word documents using a combination of MSWordStylers and the Python docx library, called from a PythonCaller. A very instructive journey :-)
To make sure I don't forget immediately everything I've learned, I have decided to summarize my findings in a template. And because a lot of input has come from this community I will share the results here. Please see the zip file attached: images-to-table-python-docx.zip
It starts by reading Parcel information from a database (gpkg) and it creates a summary table in a word document, including a little image with the parcel plotted on an aerial image.
Inspiration has been taken from these to discussions:
With some slight modifications I have integrated these two examples in my own workflow.
What do you think?
Cheers,
Egge-Jan
Edit 2024-04-05: attachment added again in zip file format (apparently the new community environment does not support the uploading of fmwt files).
nielsgerrits
Forum|alt.badge.img+67
Thanks for sharing. Personally, I don't like renaming transformers, as this makes it harder to review workspaces.
mathiku
Forum|alt.badge.img+8
  • Apr 5, 2024 1:02 PM UTC
This post is just what I was looking for, but where is the template attached?
becchr
Forum|alt.badge.img+35
  • Apr 5, 2024 1:14 PM UTC
Hi @mathiku it probably got lost in translation going to the new community site
Best to report here I guess and hope someone at Safe can recover it
egge
  • Apr 5, 2024 3:57 PM UTC
Hi @mathiku, Hi @becchr,
Thanks for letting me know that the attachment was gone… The original attachment was a Safe Software *.fmwt (Template) file. But apparently the new community environment does not support this file format anymore.
I have added the example again, both the workspace and an input geopackage, but in a zip file this time. See the original, edited post above.
@mathiku: please let me know if this works for you.
Cheers,
Egge-Jan
