add dot at every line in txt file
Hello All
I'm new to FME but i think it's a great tool to help
anyway i have this problem that i hope that somebody can help me to solve it
I have a TXT file , most of the sentence are not with dot at the end.
I need to add a dot at the end of every sentence and then save the TXT file back again with the same encoding settings ( I want to make this thing to go automatically)
any help guys
thanks
Best answer by erik_jan
Use the Text reader with the setting to not read the whole file as one feature:
The use the StringSearcher, searching by \\.$ to check if the line ends with a dot.
If not, use the StringConcatenator to add a dot to the line.
Then use a Text writer to write the text line by line.
erik_jan
Forum|alt.badge.img+19
  • May 2, 2018
  • May 2, 2018
firstly thank you very much for your response , but can we do it step by step
I tried the string concatenator but without any luck ( what to write there )
erik_jan
  • May 2, 2018
See image and attached example (FME 2018):
textline2textline.fmwt
erik_jan
  • May 2, 2018
I have added a screenshot and a template with the workflow.
  • May 2, 2018
Thanks a lot Erik
another quick thing ,, it only work for certain file or I can use a watch folder for all files
  • May 2, 2018
Thanks a lot Erik
erik_jan
  • May 2, 2018
mgm21m wrote:
Thanks a lot Erik
You can use this workflow for any text file.
I used a log (.LOG) file, because that was the first I found.
