Add creation date of file A as data in a new column of file B
  • Apr 10, 2025 3:26 PM UTC
  • 143 views
valiiien
Participant
I have a file A from which I am reading the creation date through a “Directory and File Pathnames Reader”.
Now I want to add the date as data in a column of file B.
It should look like this:
ID path_created_date
1 2025-04-04
2 2025-04-04
I tried using AttributeManager, but what I get is this:
<missing> 2025-04-04
1 <missing>
2 <missing>
I am very thankful for any other ideas or solutions.
Best answer by ebygomm
You can merge the date onto the features from column B using a constant in a featuremerger
The date from your FileA goes into the supplier, the data from Fileb goes into the requestor
Forum|alt.badge.img+54
  • Apr 10, 2025 3:32 PM UTC
valiiien
Participant
  • Participant
  • Apr 17, 2025 8:05 AM UTC
Thank you very much! I could implement is in my script and it worked perfectly fine :)
