Accurate 2D points cloud to polgon transform. HullReplacer gives too 'smooth' a polygon result
  • Nov 3, 2020 10:49 AM UTC
  • 57 views
I want a more exact outline rather than a smoothed outline from a point cloud (2D) I have? See image attached
Captureat the moment I use HullReplacer which actually gives too smooth a result
CaptureCan you help
  • Nov 3, 2020 10:57 AM UTC
Have you tried playing around with the alpha value in the HullReplacer? This value defines the "smoothness" of the result. If no alpha value is given, FME will try to guess one for you, but the result might not be what you want.
See also the documentation:
http://docs.safe.com/fme/2020.1/html/FME_Desktop_Documentation/FME_Transformers/Transformers/hullreplacer.htm
  • Nov 3, 2020 11:01 AM UTC
Thanks!
