about converted b3dm files
  • Nov 28, 2017 12:48 PM UTC
  • 99 views
I've converted GDB file to 3d tiles via FME. These created titles are working fine. But,
i get the this warning at console:
This b3dm header is using the legacy format [batchTableJsonByteLength] [batchTableBinaryByteLength] [batchLength]. The new format is [featureTableJsonByteLength] [featureTableBinaryByteLength] [batchTableJsonByteLength] [batchTableBinaryByteLength]
This tile uses a lowercase refine "add". Instead use "ADD".
Required property geometricError is undefined for this tile. Using parent's geometric error instead.
what could be the reason for this?
daveatsafe
Forum|alt.badge.img+24
  • Dec 2, 2017 12:01 AM UTC
Hi @burakc,
The b3dm specifications has changed since we created the Cesium writer for FME. We are working on updating the writer to the latest specifications for FME 2018.
Hi, is there a way of creating refine= replace instead of add?
