A problem with Statistics Calculator
jan
The statistics Calculator gives this error when trying to count the sum of an attribute: 2020-08-11 12:49:59|2233.8| 2.3|ERROR |Python Exception <MemoryError>:
2020-08-11 12:49:59|2233.8| 0.0|FATAL |@Python failed to execute function `StatisticsCalculator.recordFeature'
2020-08-11 12:49:59|2233.8| 0.0|ERROR |StatisticsCalculator_2_InputProcessor (TeeFactory): StatisticsCalculator_2_InputProcessor: @Python execution failed
2020-08-11 12:49:59|2233.9| 0.1|ERROR |StatisticsCalculator_2_InputProcessor: @Python execution failed
There was approx 2.5M features passing through each one having a value of 1. So the sum operation should not be exhaustive. What could cause this? A bug?
Best answer by jan
I removed the "fme_feature_type_name" attribute and it seems to have solved the problem.
jan
  • August 11, 2020
Using fme 2019.2
srg
Forum|alt.badge.img+10
  • August 11, 2020
@jan​ Can you try running the process with only the attribute for which you need the statistics?
In other words use AttributeRemover to remove attributes of not interest for statistics calculation before sending the FME features to StatisticsCalculator.
jan
  • August 11, 2020
I can't remove but one attribute. I need all the others.
jan
  • August 11, 2020
jan
  • August 11, 2020
Should this be reported as a bug!?
DanAtSafe
Forum|alt.badge.img+18
  • August 11, 2020
Hi @jan​  Please try the latest FME 2020.2 beta and if the problem still exists then please submit a case. Thanks!
jan
  • August 12, 2020
I think Safe should test it. My Client uses FME 2019.2 and it is a hard job changing version since also FME Server is used with the same version.
