a lines intersecting operation
  • Apr 27, 2018 1:17 PM UTC
  • 6 replies
  • 83 views
lianaolianov
Forum|alt.badge.img+5
Hello,
I have a network of (+) intersecting lines (There is no (T) intersections). I have also nodes of these + intersections also extracted.
I want that whenever there is an intersection, the shortest line to be splitted to 2 lines but the long ones remains as it is
Can anyone help me with this ?
Thank you very much
danilo_fme
Forum|alt.badge.img+58
  • Apr 27, 2018 2:58 PM UTC
Hi @lianaolianov
Could you share us your workspace template?
Thanks,
Danilo
lianaolianov
  • Apr 30, 2018 9:31 AM UTC
Hi @lianaolianov
Thanks,
Danilo
Hello,
Here is my worksapce hydrographic-4quadrant-splitter.fmw
Sorry for late reply and thank you :)
jneujens
  • Apr 30, 2018 9:57 AM UTC
1) get the length of your lines by using a LengthCalculator.
2) Use a SpatialRelator and set 'Accumulation mode' to 'Merge Attributes'. Use the nodes as requestor (and make sure they have a unique id) and the lines as supllier.
3) Then use a TestFilter to compare the 2 length attributes (which should be added to the node they intersect) to see which line is the longest for each node.
4) For the shortest lines: use a PointOnLine overlayer or Intersector to split them into two segments.
5) Use a FeatureMerger to recover the longest lines from the original dataset based on their ID.
Without seeing the data I am not sure if this would cover your question completely, but it can give you a direction on how to start.
lianaolianov
  • Apr 30, 2018 10:34 AM UTC
Hello
Thank you for the reply
I am following the steps, but actually I get just One length attribute per node, how do I get the two separately ?
lianaolianov
  • Apr 30, 2018 10:58 AM UTC
Hello,
I solved the problem by creating a list and exposing the two lengths as attributes
jneujens
  • May 2, 2018 10:34 AM UTC
Hello,
Great to hear!
