2024.2 yields an error in SharepointOnlineConnector ?
lifalin2016
Forum|alt.badge.img+29
Hi.
I built a workspace in 2024.1, that fetches a number of files from a customer Sharepoint site. It works (in 2024.1) without problems.
I just installed 2024.2, and ran the workspace (with no changes).
Now it issues an error with a SyntaxWarning from the package “safe.microsoft-sharepoint”:
C:\Users\xxx\AppData\Roaming\Safe Software\FME\Packages\24783-win64\python\safe.microsoft-sharepoint\stringcase.py:247: SyntaxWarning: invalid escape sequence '\W'
  return re.sub("\W+", "", string)
Is this something that I should worry about ?
SharepointOnlineConnector is not listed as an upgradable transformer in 2024.2
Cheers.
nielsgerrits
Forum|alt.badge.img+54
Have you tried uninstalling and reinstalling the package?
If this does not resolve your issue I would submit a ticket.
lifalin2016
  • November 20, 2024
I don’t want to do that right now, since another virtual machine is running the same workspace with 2024.1 as a scheduled task.
I just upgraded FME 2024 locally to see if there were any issues, before upgrading on the VM.
I guess I found one, so I’m not upgrading FME 2024 on the VM at this time.
hkingsbury
Forum|alt.badge.img+55
  • November 20, 2024
I wonder if it is a python version issue. do you have the same python versions installed on each machine and the same version compatibility set?
Asking chatgpt, it suggests that after 3.6 python would begin raising syntax errors when strings with escape characters (“\”) weren’t declared as raw strings.
https://chatgpt.com/share/673e31ac-fd98-800f-b74e-0aecdf38ae84
If changing the python versions doesn’t work (or isn’t possible in your setup) then yes, its definitely something for Safe to investigate!
lifalin2016
  • November 21, 2024
As far as I can tell, FME 2024.1 and 2024.2 embeds the same Python version: 3.12.
I assume the transformer (SharepointOnlineConnector) uses the embedded Python, so unless 2024.1/3.12 != 2024.2/3.12, I don’t see an issue here.
I have submitted a ticket. It’s probably an easy fix in the code, and may be just a friendly warning, but I would like to be sure before upgrading our production version.
chriswilson
Forum|alt.badge.img+11
  • January 6, 2025
I have also come across this error today.  I haven’t had time to fully examine it as yet but there’s this and also a datetime function deprecation (below - not an FME page but found when searching an error we encountered today in Flow and Form) that have both arisen around FME 2024.2 and python.  I’ve mentioned both to our NZ FME reseller.
https://stackoverflow.com/questions/78634993/why-cant-i-ignore-this-datetime-datetime-utcnow-deprecationwarning
lifalin2016
  • January 7, 2025
I got this reply from Safe support:
  • Our development team has informed me that this warning, logged as an error, is expected and not harmful.
    - and -
    Unfortunately, there aren't any plans to change this behaviour for now.
    This warning is generated from a third-party Python library included with the SharePointOnlineConnector.
    In FME, SyntaxWarnings generated by third-party Python code are displayed as red error text.
    I have put a note in our system as a possible enhancement request, but these requests don't have a specific timeline.
So this is apparently just a 3rd party warning, that’s unfortunately shown as an error in FME.
lifalin2016
  • January 7, 2025
chriswilson wrote:
This actually looks like a quick fix, that could easily be applied to the SharepointOnlineConnector code.
chriswilson
  • January 9, 2025
    - and -
Interesting.  Unfortunately we have a long-running process with a lot of features being written to ArcGIS Online and the additional logging was causing memory issues on our Flow Hosted server.  Will have to think around that one!
chriswilson
  • January 9, 2025
Just updating on my previous comments - that error may be more related to interactions between Flow 2024.2 and ArcGIS Online and not relevant to this thread.  I am uncertain if the SharepointOnlineConnector also triggers this error.
sfb
Forum|alt.badge.img+3
  • April 4, 2025
Any updates (or workarounds) for this? Ran into the same issue today.
natalieatsafe
@sfb Hi there, sorry to hear you’ve encountered this one! What version of FME Form / Flow are you working with? Is the SharePointOnlineConnector failing in your workspace when you see this warning logged? Or are you still receiving expected results despite the warning?
sfb
  • April 7, 2025
Hi Natalie. I’m using FME Form v2024.2. I’m able to successfully add the SharePointOnlineConnector transformer to the canvas but the error presents itself when attempting to select the site from within the transformer parameters. I receive the same python syntax error in the log as the OP.
natalieatsafe
@sfb Could you please open your FME Workbench 2024.2, then access Tools > FME Options > FME Packages. Single-click on the SharePoint Online package in the list of packages showing, and then check it’s version in the information that populates about the package. What version of the SharePoint Online package are you currently working with?
sfb
  • April 9, 2025
Thanks for the reply Natalie. I’m using version: safe.microsoft-sharepoint [1.2.2]
natalieatsafe
@sfb Sorry to keep on this point, but I just want to confirm one thing. Does this error message completely prevent you from configuring the SharePointOnlineConnector? Or do you receive this error in the translation log window, but you can still select a site for the Site parameter, and carry on configuring the connector? I’m trying to determine if what you’re seeing is something we know about, or something new. Thanks!
sfb
  • April 14, 2025
No worries Natalie. It does completely prevent me from configuring the Sharepoint connector (see attached pic). Many thanks.
natalieatsafe
Hi all, just posting an update on how things are looking based on working ​@sfb ‘s error through in a support ticket. The error that was thrown upon selecting the ellipses to the right of the Site parameter of the SharePointOnlineConnector comes from the use of Sites.Selected scope on the Azure app registration.
When those ellipses are selected, a specific Graph API call is triggered to generate the list of sites that users can select from in the separate Edit Selection dialog. This Graph API call does not support the Sites.Selected scope, and will throw an Access Denied error when the ellipses are selected. So a limitation of the Graph API in play here.
The way around this issue is to manually populate the connector’s Site parameter with the needed site identifier value. This value can be manually populated by selecting the drop-down menu to the right of the Site parameter (the little black triangle), then choose Open Advanced Selection Editor. Manually enter the site identifier into the Object Identifier column of the Advanced Selection Editor, and then type in a Display Name of your choosing.
This site identifier value takes the form:
<hostname>,<siteId>,<webId>  **single comma between values, no spaces
Most SharePoint / Azure Admins would know how to acquire the needed values to construct the site identifier; these values are not typically exposed to the end user in a web browser, so no easy way to find these values by navigating the site in SharePoint Online.
We will put up some more detailed instructions on working with the Sites.Selected scope and the SharePointOnlineConnector soon; I’ll update this thread with a link to those instructions once published.
sfb
  • May 15, 2025
Hi there Natalie. Can confirm that we’ve done as you suggested and added the site ID to the SharePointOnline reader. I can now successfully download an Excel file hosted on the Sharepoint site using the azure app authentication method via FME Form. Thanks very much for the assistance.
