What is the best way to download data from an Open Data ArcGIS Site that does not require a login?
  • November 15, 2022
  • 7 replies
  • 67 views
tcronin
Forum|alt.badge.img+3
Best answer by evieatsafe
tcronin wrote:
Trying the URL triggers an error.
Hi @tcronin​ I was able to load this data into FME using the URL found at the bottom of your feature service (https://gis.countyofriverside.us/arcgis_public/rest/services/OpenData/ParcelBasic/MapServer/) I used the ArcGIS Server Feature Service Reader.
Under the parameters I made sure to choose the Authentication type 'None' and populate the Layer that you wish to use (in the red box).
If you are still receiving errors after this please let us know!
nielsgerrits
Forum|alt.badge.img+55
This is a very broad question. Are you talking about a webmap, web viewer or arcgis service? What kind of service? Sample site?
tcronin
  • November 15, 2022
Sorry, learning all this. The Link I am trying to setup is here. https://www.arcgis.com/home/item.html?id=47ad3e55e5c94243b1ecf1629d210452, should be a feature service.
michiedem
Forum|alt.badge.img+7
  • November 15, 2022
Left bottom of the website in your link you can see an URL, copy the URL and paste in an Esri ArcGIS Server Feature Service reader. Done, that is all you need to do.
tcronin
  • November 15, 2022
Are you talking about the Link for the URL pointing to the Rest Endpoint?
tcronin
  • November 16, 2022
evieatsafe
  • November 16, 2022
tcronin
  • November 17, 2022
Very Helpful. I hadn't used the Server Service Reader, in fact did not even know it was there, thank you.
