Help me understand Aggregator Hierarchies?
  • February 6, 2025
  • 6 replies
  • 89 views
aron
Forum|alt.badge.img+16
Case: To get an unified look I am trying to aggreagate line features before offsetting them. Once they are offset I want to deaggregate them back to their original geometries and attributes.
I assume using ‘Geometry - Assemble hierarchy’ in the Aggregator is the way to go. Unfortunately I find the documentation a bit confusing.
Q1: Could someone please explain the parent - child concept? I have features and their attributes, so two(?) levels deep. I want to “pack” and then “unpack” them. But I don’t understand where to get the ‘parent ID’ or ‘child ID list attribute’? It would make sense to me that they were created when I group the features, not before?
Q2: In the documentation the word nodes is used frequently. I guess this should be understood as ‘parts’?
NB this might not even work. When using the setting ‘geometry - assemble one level’ features wont deaggregate after being offset. If it is also so when using Hierarchies, is there an other tool to achieve my desired result?
Best answer by joepk
The Aggregator aggregates features into a “parent” feature. All of the features in one parent feature can be seen as childs of the parent.
When aggregating, you can give features you want to aggregate into the same parent feature the same ID, and pass that ID on as a parent ID.
The child list ID is an ID you pass on to a parent feature, which will result in an aggregation of all the child IDs in the list to the parent feature which carries the list.
I hope this kind of makes sense, this is naturally confusing stuff.
A node is the same as a vertex. A line consists of nodes with edges in between them. Try to run your lines to the TopologyBuilder, this has nothing to do with parent/child IDs, but it will give some insights on how FME handles geometries.
max_h
Forum|alt.badge.img+10
  • February 6, 2025
So what do you desire as result exactly? What would be the difference to the pre-aggregated state when you’re deaggregating geometries and attributes?
Sounds to me that you could simply use your original features or am I mistaken?
aron
  • February 6, 2025
The reason I want to merge the line features is that they sometimes self intersect when being offset if they are separate features. I also trim the ends in a way that is easier managed if they are merged. Once in an offset position I need to return to the original parts since they contain important attributes needed for later processing. I am trying to find a way to simplify the geometry as much as possible before offset, to avoid having to do a bunch of repairs afterwards, like removing dangles and similar.
max_h
  • February 6, 2025
In your aggregator you can generate a list of your wanted attributes and after you offset your lines you can use a deaggregator and explode said lists
aron
  • February 7, 2025
Unfortunatly the deaggregator does not split the lines after offsetting when using the ‘geometry - assemble one level’ setting. Thats why I am trying to see if ‘Geometry - Assemble hierarchy’‘Geometry - Assemble hierarchy’ is the way to go.
max_h
  • February 11, 2025
If you havnt solved it already by yourself, a small sample of your data/lines and/or a picture of your workspace with its configuration could help us to help you.
joepk
Forum|alt.badge.img+20
  • February 11, 2025
