convert MDB TO OBJ
I'm attempting to convert a series of MDB's to OBJ's. However, I'm getting this error:
OBJ Writer: Unknown geometry type 'IFMENull' is not supported, the feature will not be written
I tried using a 'geometry filter' to get rid of all null values, but that didn't work either.
  • January 16, 2018
Hi @cyrusblankinshi, as far as I know, the MDB (Microsoft Access) format itself doesn't support storing any geometry data. See also here: Microsoft Access Quick Facts
How did you create geometries from the source MDB dataset? What kind of geometries are shown if you send the features to FME Data Inspector?
  • January 16, 2018
And, what type geometries have remained after you did get rid of the Nulls with the GeometryFileter?
It is a file format that Neverwinter nights 1 and 2 use for their models
