dangle nodes and pseudonodes
  • July 13, 2017
  • 73 views
I am a newbie to FME. I need to create nodes from a road network shapefile. Initially in ESRI, I created a network dataset and subsequently nodes. The resulting dataset had pseudo-nodes and dangle nodes along edges and at ends of segments. This wasn’t what I wanted. How do you distinguish between intersection and overpasses? How can I use FME to generate nodes only at intersections? I will appreciate it if you can send me a workflow.
Best answer by erik_jan
First I would have a look at the TopologyBuilder transformer.
See if that matches your requirements.
erik_jan
Forum|alt.badge.img+26
  • July 13, 2017
