FMECloudInstanceController - How to retrieve Instance ID?
  • April 18, 2018
  • 46 views
I am trying to retrieve FME Cloud Instance ID to be utilized on the FMECloudInstanceController transformer, but it seems that it is not available through the Server UI.
How am I able to retrieve them? Server API?
Thanks!
John
Best answer by jmoura
I figured it out. There is no easy way to retrieve it through the UI anyway.
You need to leverage FME Cloud API to retrieve it.
Attached is a simple process that will retrieve IDs once you provide the Token.
fmecloud-instance-id-retriever.fmw
  • April 18, 2018
  • April 18, 2018
Another option according to FME Experts is to leverage the FMECloudInstanceLister, which will do the same job in a more streamlined process.
More information here:
https://hub.safe.com/transformers/fmecloudinstancelister
