Rasterconvolver changes depth of color, why ?
  • October 26, 2018
  • 24 views
I am using an Rasterconvolver for image recognition - the input image raster is a 8bit grey value. After transforming i'll do get an 64bit result. How can I manage it, to get the same output depth ?
xiaomengatsafe
Forum|alt.badge.img+11
Hi @witte. I've not played with the RasterConvolver myself. But I know we have a transformer called RasterInterpretationCoercer that can convert between different interpretation types. Maybe it will help in your case?
daveatsafe
Forum|alt.badge.img+20
  • October 26, 2018
Hi @witte,
The RasterConvolver has an option near the bottom to Preserve Band Interpretation. Please set that to Yes.
  • October 27, 2018
Thanks a lot - as a matter of fact, i use now both of your tips and it works well.
