I’m trying to store in a geodatabase all points from a layer that shares the exact same location. These points are before aggregate in order to have only 1 point to represent the share location.
My workspace works well, but when I execute it, even if the FME log tells me that only 7598 points has been inserted in the database, when I look in it there are 42903 points added.
Here is my log file:
https://docs.google.com/file/d/0B6AQWwPegRg6ZXFvTEE5bmlmTms/edit?usp=sharing
Here is the select count in the database:
https://docs.google.com/file/d/0B6AQWwPegRg6a2pnaWVuY0Y1MDA/edit?usp=sharing
Now here is an extract of my workspace:
https://docs.google.com/file/d/0B6AQWwPegRg6TDE1T3gtbXdyMUk/edit?usp=sharing
As you can see the number of elements before the Aggregator is the same as the one in the database.
Finally here is the inspection done with ArcMap:
https://docs.google.com/file/d/0B6AQWwPegRg6ZnJVOHV1elV5dEk/edit?usp=sharing
So I would like to understand what I missing? Can you help me please?
Thanks
