creating sampling hexagons
  • June 14, 2018
  • 5 replies
  • 76 views
arthy
Forum|alt.badge.img+8
Hello,
Is there a way to create sampling hexagon using fme (and python caller) that would cover a study area?
Basically, the idea is to create a mesh of sample hexagons and ensure that that all regions within the study area are represented by the sampling results as you can see in this post?
Thanks
Best answer by larry
I just published the HexagonSampler on the FME Hub.
  • June 14, 2018
arthy
  • June 19, 2018
Thanks @larry,
I sligthly modified it but the main idea was there.
Thanks again
  • June 19, 2018
Thanks @larry,
Thanks again
I you want to share your modifications, I can update the transformer on the hub to share with others.
arthy
  • June 19, 2018
I passed the input and the output of the arcstroker trough a spatial filter so that only hexagons that intersects the input will come out.
fikusas
Forum|alt.badge.img+5
  • December 4, 2019
When passing calculated value from attribute, results are incorrect. How can I pass Hexagon Side Lenth value from the attribute?
