SDF reader with multiple geometry columns
  • March 8, 2017
  • 26 views
Hi, a user has an SDF file with several geometry columns:
https://knowledge.safe.com/questions/40984/how-to-select-the-right-geometry-column-in-sdf-fil.html
Is this supported by FME, if so, how? I couldn't find any setting for this in the SDF reader.
  • March 8, 2017
I'm also interested in this subject. I'm wondering if the SDF reader can read a multiple geometry as an aggregate and each part of the aggregate has the geometry column name as its geometry name or a trait. However, I don't have any sample SDF dataset containing multiple geometry features, so cannot confirm that unfortunately.
In addition, I would like to know how to write multiple geometry features into a new SDF dataset with the SDF writer.
fmelizard
Forum|alt.badge.img+21
  • March 8, 2017
Thanks @david_r and @takashi. I will find a technical or strategic expert to respond to the initial questions as well as your follow up questions. Thanks!
fmelizard
  • March 9, 2017
  • March 10, 2017
Hi @NatalieAtSafe, yes I know that the Quick Fact describes that the SDF reader/writer doesn't support aggregates, but surprisingly, in my observation, the reader/writer can read/write aggregates in fact.
In addition, the SDF writer has a parameter called Geometry Column Name, and the help doc says "A comma-separated list of the geometry column names for writing". I therefore thought that the SDF writer supports multiple geometry and the user could specify the geometry column names through the parameter. However, the writer seems to write a multiple geometry as just an aggregate.
See also the attached workspace: sdf-vs-mutliple-geometry.fmw
