Does FME support reading Geosoft Geodatabse with the extension .gdb?
  • January 22, 2018
  • 68 views
Does FME support reading Geosoft Geodatabse with the extension .gdb? If yes, which reader can be used?
  • January 23, 2018
I assume your referring to Geodatabases created using the Geosoft 'Target for ArcGIS' product. If this is the case then I would guess the FME File Geodatabase reader. If FME cannot read these .gdb datasets then perhaps zip and attach a small example to this question and we can take a look.
  • January 24, 2018
The geodatabase i am referring to comes as a file rather than a folder. So the FME File Geodatabase Reader doesn't recognize it.
karthika
Participant
  • Participant
  • April 1, 2025
I am also facing this issue now. were you able to resolve it?
