For FME 2011 ESRI Shapefile Writer, what is the maximum column name length?
  • May 29, 2014
  • 18 views
  • May 29, 2014
Every field name length for a shape file should be 10 bytes or less. It's restricted by the shape format specification.
Takashi
  • June 2, 2014
Beware that the shape file is a very old format and that it has a lot of limitations. See the doc for more info (http://resources.esri.com/help/9.3/ArcGISDesktop/com/Gp_ToolRef/geoprocessing_tool_reference/geoprocessing_considerations_for_shapefile_output.htm).
David
