Using FME to run an Oracle begin/End statement
fmelizard
Forum|alt.badge.img+18
I'm using the "SQL Statement to exectute at end of translation".
I've set it to:
FME_SQL_DELIMITER ;
... Other SQL...
begin DBMS_SNAPSHOT.REFRESH( '"OSMM"."OS_ABP_V_DELIVERY_ADDR"','C'); end;
This works fine in Oracle SQL Developer (ti's to refresh a materialized view). But when I run it via FME I get Oracle errors.
2014-08-12 16:43:46|   2.3|  0.0|ERROR |Execution of statement `begin DBMS_SNAPSHOT.REFRESH( '"OSMM"."OS_ABP_V_DELIVERY_ADDR"','C')' did not succeed; error was `ORA-06550: line 1, column 67:
PLS-00103: Encountered the symbol "end-of-file" when expecting one of the following:
Removing the "End;" or the ";" or both does nothing, I just get a slightly different varient on the same error.
Is it possible to run such a statement like this?
Thanks,
Jonathan
fmelizard
  • August 12, 2014
use another FKE SQL delimiter than ; ( : for example)
  • August 12, 2014
Hi Jonathan,
Although I'm not familiar with Oracle syntax, the reason may be that FME considered the semi colon before "end" as the end of a statement.
How about changing delimiter character (FME_SQL_DELIMITER)?
Takashi
  • August 13, 2014
I recommend removing the whole line containing FME_SQL_DELIMITER. You do not need it for anonymous blocks.
FME will give you a warning about the semicolons in the log window, which you can ignore.
If your SQLExecutor has other DML statements that require FME_SQL_DELIMITER, I'd recommend splitting them out into a separate SQLExecutor.
David
  • August 13, 2014
I have tried running a similar scipt in the SQLCreator and I can't get it to work not matter what I try. I ended up splitting the script up into three seperate Creators but you have to be careful as to which creator runs first.
