Python TruncateTable_management not working with getAttribute list
  • May 4, 2020
  • 59 views
I am trying to run a python script in a PythonCaller to Truncate Features in an Oracle ArcSDE database.
If I run the script and hard code the Feature it runs fine but when I try to use feature.getAttribute to read a list created in a previous transformer, I keep getting:
Python Exception <ExecuteError>: Failed to execute. Parameters are not valid.
ERROR 000187: Only supports Geodatabase tables and feature classes
My script is:
# Import arcpy module
import arcpy
def processFeature(feature):
IFeatures = ('C:\\\\AppData\\\\Roaming\\\\ESRI\\\\Desktop10.5\\\\ArcCatalog\\\\Connection_to_HYDRA.sde\\\\' + feature.getAttribute('_list{0}'))
print (IFeatures)
for mark in IFeatures:
arcpy.TruncateTable_management(mark)
Forum|alt.badge.img+46
  • May 4, 2020
I don't have access to arcpy right now so i'm not 100% sure on setting the environment for sde but normally I'd expect the code to look something like this
import arcpy
    arcpy.env.workspace = "C:\\AppData\\Roaming\\ESRI\\Desktop10.5\\ArcCatalog\\Connection_to_HYDRA.sde"
    IFeatures = feature.getAttribute('_list{}')
So set the environment, and then get the list (I'm presuming you want all list items, as your posted code only references the first list item (_list{0})
  • May 4, 2020
import arcpy
Thanks @ebygomm, that did the job.  I did want all the list items as well.
