I have a workbench where, at the start of it a number of features are selected through a Tester that fulfill a certain criteria.
I then want to run the workbench multiple times, each time using one of the features. But I don't want all the features to go through the workbench at the same time as this will not work in the way it is set up.
Is there a transformer that will enable me to run it one feature at a time?
Thanks,
