Delete duplicate values from multiple string attributes
  • July 2, 2019
  • 87 views
I have features with about 15 string attributes. Each of these attributes has to be split into a list in order to delete duplicate values. I have already used an AttributeSplitter followed by a ListDuplicateRemover. But since I have 15 attributes, I was wondering if there is a more effective way of doing this instead of having 15 AttributeSplitters and 15 ListDuplicateRemovers.
Thank you!
danilo_fme
Forum|alt.badge.img+45
  • July 3, 2019
Hi @nademmy
In your case I suggest you to use the custom transformer MultiAttributeSplitter:
https://hub.safe.com/publishers/pacific-spatial-solutions/transformers/multiattributesplitter
Thanks,
Danilo
