Best Answer
Spatial relator
  • January 2, 2014
  • 17 views
Helo I am simply  tring to run a test to determine if poitns are within Parcels and it seems to working well but there are Lat Long field that are not being populated. Is there a way to populate these fields?
Thanks
Pat
Best answer by dai
Hi
I think the Points and Parcels both have the field Lat and Long what cause  the field can not be populated. If you use the SpatialRelator ,the relate information will hold in a new list. I advise you to read the description of this transformer.you will get it. Or you can use the AttributeRemover to remove the field before  using the SpatialRelator
  • January 3, 2014
Hi
