I am trying to download several shape files from a government website that does not require authentication. I am using the SHAPE reader but keep getting the error "No Shape files found in specified directory. Check if directory specified is valid"
Below is the website:
http://aep.alberta.ca/forms-maps-services/maps/wildlife-sensitivity-maps/default.aspx
And this is what I am putting in the Dataset Parameter:
https://extranet.gov.ab.ca/srd/geodiscover/srd_pub/LAT/FWDSensitivity/BurrowingOwlRange.zip/Burrowing_Owl_Range.shp
I am sure the mistake is minor but I can't figure it out. Thanks for the help in advance.
Justin
FME 2014 SP2
