repair geometry function
  • November 12, 2012
  • 83 views
gisbradokla
Forum|alt.badge.img+16
I have a workspace I recently completed that creates a buffer of a line featureclass.  I dissolve it into single polygons and run a chopper to limit the polygons to 8000 vertices.  I have now discovered that the resulting shape file has self intersecting polygons.
I ran the repair geometry in ARCMAP and validate this fact.
Looking at the transformers there is a selfIntersector which I added to my workflow but I still get self intersetcions after running. I don't see any options on the selfintersector.  Am I  missing something?
Can someone help?
Best answer by mark2atsafe
I'm not sure why we would create self-intersecting polygons, but it's not good! In this case, can you try using FME2013. I know it's not released yet but...
1) The Chopper polygon-chopping has been vastly improved
2) There is a new GeometryValidator transformer to repair bad geometry
You could certainly report this to the support team, if so please include your data so we can test it for ourselves in 2013.
Regards
Mark
Mark Ireland | Product Evangelist
Safe Software Inc.
Suite 2017, 7445-132nd Street, Surrey, BC, CANADA
T 604.501.9985 | F 604.501.9965
| Twitter @FMEEvangelist | http://www.FMEevangelist.com
mark2atsafe
Forum|alt.badge.img+44
  • November 13, 2012
Regards
Mark
Safe Software Inc.
gisbradokla
  • November 19, 2012
thanks mark,
  I did try 2013 and either don' thave teh validator set correctly or it is not working as you indicate it could.  I also submitted a support request for this.
The file tha tI get using th e passed only port still has the same repaired features when I run repair geometry on it in arcmap.  I don't get anything out of the repaired port.
