Having StringReplacer write to another field in the record
  • November 29, 2016
  • 25 views
I was wondering how to have a constant value write to a different field in my record using StringReplacer. In the example below, if TIM Number = 89, I would like to have the constant ELITE written into the Meter_Type field.
Best answer by itay
Another option is to use the AttributeManager with conditional values.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • November 29, 2016
I think the transformer you want is the AttributeValueMapper
itay
Forum|alt.badge.img+18
  • November 29, 2016
Hope this helps.
  • November 29, 2016
I was unsuccessful doing this with the StringReplacer, so I ended up using the AttributeManager, setting the value for Meter Type using a Conditional Value for TIM Number defined in the Attribute Value column. FME Support told me that this bug using StringReplacer is fixed in the FME 2017 release.
