Executing Stored Procedure using Sqlexecutor.
  • July 4, 2013
  • 39 views
I am facing problems while executing parameterised stored procedure using sql executor. Error log prints the error statement with parameter values, and when I use the same statement to execute directly in oracle, it runs properly.
Best answer by david_r
have you tried somthing like this?
begin
    my_stored_proc(
        proc_param_a => '@Value(my_attribute_a)',
        proc_param_b => '@Value(my_attribute_b)'
end;
If that still does not work, consider posting more details.
David
  • July 4, 2013
begin
    my_stored_proc(
end;
David
